1994 Plymouth Sundance car misses when warm
1994 PLYMOUTH SUNDANCE
112,567 MILES • 4 CYL • FWD • AUTOMATIC
ARBOGAST
i ran the car completely out of gas and its been acting up when it gets warm so i changed the fuel filter and cleaned the fuel injecter this only happens when it gets warm if i let it set for a liitle bit it starts right up please help
Aug 5, 2009 at 1:56 PM
  • 110,240 POSTS
You need to check the fuel pressure when it won't start. Chances are the fuel pump is causing the problem. Here is a how to for checking the pump. CHeck it and let me know what you find.
https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
Aug 12, 2009 at 4:59 PM
