1991 Sundance won't turn over. Neutral switch is OK. Relay clicks when ignition switch is engaged. Don't really want to remove starter if I don't have to. Looking to check relay. Per Rasamataz's suggestion removed yellow wire from relay. Where should power be when ign switch engaged? Thanks
Jul 14, 2009 at 1:16 AM
