Check engine light:
PLYMOUTH
BRENT32
I have a 1998 Plymouth Grand Voyaguer V6 3.0 with 140,000 miles and the check engine light keeps coming on. I had a mechanic look at it and said the O2 sensors needed to be replaced. I have done that and the reset the light. The light has now come back on, there are several codes that it displays. They are 12, 43, 72, 55. Can you tell me what those codes mean?
Aug 16, 2006 at 9:47 AM
MIKEYBDMAN
  • 623 POSTS
[quote:c2994eb800="Brent32"]I have a 1998 Plymouth Grand Voyaguer V6 3.0 with 140,000 miles and the check engine light keeps coming on. I had a mechanic look at it and said the O2 sensors needed to be replaced. I have done that and the reset the light. The light has now come back on, there are several codes that it displays. They are 12, 43, 72, 55. Can you tell me what those codes mean?[/quote:c2994eb800]
Code 12: Battery was disconnected.
Code 43: OD Solenoid circuit fault
Code 55: I dont see one
Code 72: I dont see one
Aug 16, 2006 at 10:08 AM
BUZZIN
12 MEANS BATTERY RECENTLY DISCONNECTED 43 MEANS THREE THINGS PEAK PRIMARY COIL CURRERT NOT ACHIEVED WITH MAX DWELL TIME OR CYLINDER MISFIRE OR PROBLEM IN POWER MODULE TO LOGIC MODULE INTERFACE 72 I DONT NO SORRY
Mar 13, 2007 at 3:05 PM
LISA777
  • 8 POSTS
55 means end of codes
Mar 30, 2007 at 1:21 AM
