1995 Plymouth Neon my 95 neon is over heating
1995 PLYMOUTH NEON
BUDDY07
Engine Cooling problem
1995 Plymouth Neon Two Wheel Drive Manual 155000 miles
i have a 95 plymouth neon that keeps over heating on me. i replaced the thermostat and it still over heats. when i fill the coolant up after i drive a few miles an stop i notice that the radiator isnt pushing it back into the coolant resovoir. the coolant is empty. the fans run an air is coming through.
Feb 27, 2009 at 12:19 AM
Check the radiator if its clogged up and the water pump if its functioning-if okay could be air lock in the system try bleeding it, if it continues to overheat get it block and pressure tested.
Feb 27, 2009 at 6:11 PM
