Ok I have a 1995 neon on any day it will start and idle fine I drive 20 mins to work every morning and it runs fine and have never had any issue at night but on hot days like 80 degree plus days if I try to make that same trip home and back it will start to cut out and then soon after die but while its cutting out if I barely press on the gas peddle it will slowly accelerate but if I put the peddle to the floor it pop and will just come to a stop one it will no longer run or start I let it sit for like 20 mins to an hour it will start and run fine but not for long if I let it sit long enough for the temp gauge to go all the way down it runs as if nothing was ever wrong I put a new ignition coil on today and after I put it on I started the car and it started missing as soon as I tried to give it an gas I put the old one back on and it throttles up just fine re hooked up new one and it wouldn't even start please help me
Sep 18, 2015 at 10:19 AM
