1999 Plymouth Breeze fuel pump
1999 PLYMOUTH BREEZE
PROFESSIONAL6
1999 Plymouth Breeze 4 cyl Two Wheel Drive Automatic
where is the fuel pump located and do you remove and replace it. also how can i tell if it's bad
Sep 22, 2008 at 6:05 AM
ZACKMAN
  • 4,202 POSTS
Before you assume that the pump is bad, make sure that the fuel pump relay is working. When you first turn the key on, can you hear the pump turning on?
Fuel pump is in the fuel tank. Relieve fuel pressure, remove 2 straps that are holding the tank up, on top of the tank, unplug the connector and make sure you have power to the connector. If you do, remove the ring that is holding the fuel pump in place, and pull the pump out. Install is reverse.
Sep 28, 2008 at 12:34 PM
