1996 Plymouth Breeze fuel pump
1996 PLYMOUTH BREEZE
SWEETSTEPHANY
Engine Mechanical problem
1996 Plymouth Breeze 4 cyl Front Wheel Drive Automatic 180xxx miles
the car died and refuses to start...it will turn over..is this the fuel pump? and if so howhard to change?
Sep 6, 2008 at 8:07 AM
Do below to determine if its fuel or spark problem
Get a carb cleaner and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel problem, check the fuel pressure to rule out the fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil,distributor pick-up coil, ignition control module, cam and crank sensors-
Sep 6, 2008 at 8:15 AM
