Test for injector pulse using a small bulb called a noid light. If none found, check for power supply at one side of the injector with the key on.
Use a fuel pressure gauge to test for correct fuel pressure, also noticing if the pressure holds when key is shut off.
SPONSORED LINKS
Saturday, September 4th, 2010 AT 1:18 PM
