1998 Plymouth Breeze oil leaking
1998 PLYMOUTH BREEZE
TRACEY37
Engine Mechanical problem
1998 Plymouth Breeze 4 cyl Wheel Drive Type unknown Automatic 109900 miles
I replace the head gasket on my car in June of 2006. I am leaking oil again. I took it to a mechanic and he said that he sees where the head has been replaced and that it looks like the oil is coming from the head. Upon researching, I found out that the oil could possibly be coming from a leaking valve cover gasket. Could that be the case? I live in Bronx, NY. I have driven this car to Georgia and Boston and back. I never had a problem. Could it be the valve cover gasket? The replaced head isn't even 2 years old.
Mar 12, 2008 at 9:25 AM
WAYNENISSAN2000
[quote:00e7f36355="Tracey37"]Engine Mechanical problem
I replace the head gasket on my car in June of 2006. I am leaking oil again. I took it to a mechanic and he said that he sees where the head has been replaced and that it looks like the oil is coming from the head. Upon researching, I found out that the oil could possibly be coming from a leaking valve cover gasket. Could that be the case? I live in Bronx, NY. I have driven this car to Georgia and Boston and back. I never had a problem. Could it be the valve cover gasket? The replaced head isn't even 2 years old.[/quote:00e7f36355] yes if the mechanic did not have a new one
Mar 12, 2008 at 9:46 AM
SERVICE WRITER
  • 9,123 POSTS
You should get a good look at the cam position sensor as it is often mis-interpreted for a head gasket leak. Also a suspect would be a cam seal. There is a retainer that may have not been put on that may allow the seal to push out.
https://images.2carpros.com/forum/automotive_pictures/30961_acamsea_1.jpg
The first thing to check is going to be the pcv system to be sure it isn't plugged as it will allow a pressure build up inside the motor to force leaks.
Mar 12, 2008 at 10:34 AM
