I have an oil leak somewhere above the filter. Oil runs down dripping off of the filter only when the engine is reved up
Apr 28, 2009 at 11:05 AM
✓Experienced Mechanic
That is where the oil sending unit is located. Chances are it is leaking from there. Remove the filter and you will see it. I believe it is around a 20 dollar part.
Let me know if this helps.
May 10, 2009 at 1:14 PM
