1996 Plymouth Breeze OIL LEAK
BUCKBUC
  • 1996 PLYMOUTH BREEZE
  • 4 CYL
  • 75,000 MILES
THIS CAR HAS A OIL LEAK ON THE TOP REAR OF ENGINE THOUGHT IT WAS VALVE GASKET CHANGED
THE GASKET BUT STILL LEAKS THE SAME ABOUT A QUART A 1OO MILES. ENGINE WET JUST BELOW VALVE COVER AREA IN REAR IS THERE A SENSOR BACK THERE CAN'T REALLY SEE WHERE THE OIL IS COMING FROM MATBE A HEAD GASKET WHAT IS YOUR BEST GUESS. THE CHECK ENGINE LIGHTS OR CODES ARE NOT ON. BUT THE UNDECARRAGE AND REAR ENGINE ARE SOAKED
THANKS
ED
Sunday, March 30th, 2008 AT 11:51 AM
BMRFIXIT
  • 19,053 POSTS
Its the head gasket
Thursday, April 3rd, 2008 AT 6:57 PM
THOMAS29
  • 6 POSTS
Read your post, my car has the exact same problem, I was wondering if it was the head gasket? And if you replaced it yourself how hard it was?
Saturday, December 6th, 2008 AT 5:03 PM
BMRFIXIT
  • 19,053 POSTS
Common is headgasket
u need to do some checking
check oil pressure switch and valve cover gasket
wash clean engine and check
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
_________________
Saturday, December 6th, 2008 AT 5:14 PM
