1998 Plymouth Breeze
KMATA8808
  • 1998 PLYMOUTH BREEZE
  • 4 CYL
  • FWD
  • 137,000 MILES
My car isnt getting no spark I replaced the coil pack and still wont start it turns over just wont start checked all the relays and fuses they are all good I dont know whats wrong with it
Friday, February 26th, 2010 AT 3:09 PM
JDL
  • 16,098 POSTS
Hi, engine cranking, do you have primary voltage at the coil pack, dark green wire with orange tracer? The asd relay supplies voltage to coil--injectors--02 heater circuit? I'd have to check relay circuits for voltage and ground. The pcm grounds the coil side of asd relay in order to energize. A common reason for no ground, is the computer doesn't see the proper cam and crank sensor signal. I can't be sure what is wrong without testing.
Friday, February 26th, 2010 AT 3:45 PM
