trouble starting
PLYMOUTH ACCLAIM
FREE106
I have a '91 Plymouth Acclaim; Mileage: 145,422. Just recently, my car has had trouble starting. When starting the car in the morning, it will start, but after a few minutes it will cut out. I've noticed that when restarting it a couple more times,the car runs smoothly only when the temperature guage moves to hot and then levels out. However, if it has been more than five hours since I last used the car, it will do the same thing until the temperature gauge heats up. My car has been overdue for an oil change, as well as fuel filter change...could that be the problem?
Aug 10, 2006 at 4:36 AM
2CARPRO JACK
  • 11,533 POSTS
Could be a faulty coolant temperature sensor.You might have to have the ECM scanned for troublecodes. But in the mean time change your oil and fuel filters. Good maintenance will only make your car last longer
Nov 30, 2006 at 9:32 AM
