My car ia a 1991 Plymouth Acclaim. It has a 2.5 non turbo engine with 195000 miles on it. It was idling rough for a while then the camshaft broke. I replaced the camshaft but it still idles rough. It idles rougher when it is in gear. I have replaced wires, plugs, injector, coil. Timing is correct. Can find nothing wrong. Can you help? Thanks. Also, there are no trouble codes on computer.
SPONSORED LINKS
Friday, April 20th, 2007 AT 12:53 PM
