1991 Plymouth Acclaim Code 35 Fan Relay Fix
BEENSAVED
My 91 Plymouth Acclaim 4 Cyl that has about 250 k miles is having trouble code 35. I have found that is "Cooling Fan Relay Circuit Open or Shorted". Now, I need to know how to fix it. Any advice/direction. Thanks.
Jan 11, 2007 at 12:33 AM
2CARPRO JACK
  • 11,533 POSTS
The cooling fan relay( left inner fender). Dk blue wire= hot with ignition switch, gray= hot all the time from battery, lt green goes out to fan and turns into either blk/white or solid black, dk blue/pink is the signal from pcm to turn fan on. Check for powers at relay to start
Jan 11, 2007 at 7:04 AM
Suggested Repair
Locate the cooling fan relay on the left inner fender and check for power there first. Dark blue should be hot with the ignition on, and gray should be hot at all times from the battery. Light green feeds the fan, and dark blue/pink is the PCM signal that turns the fan on.
Conversation Summary
The owner of a 1991 Plymouth Acclaim with about 250,000 miles has trouble code 35, cooling fan relay circuit open or shorted, and asks how to fix it. The expert identifies the relay on the left inner fender, describes the wire colors and functions, and advises checking for power at the relay first.
