1993 Plymouth Acclaim Hesitation Shutoff
KIMMIE1010
I have a 1993 plymouth acclaim that I have replaced the starter, catalytic converter, new battery, and major tune up done on in the last 2 weeks. But it is still hestitating and shutting off, and still seem to be lossing power. Will a OS/2 sensor cause theses problems, or is it something else? [/b]
The car has about 147, 000 miles on it, and the fuel filter has been replaced.
How do you get the codes off this type of car; or is the codes what lights are on when the problem happens? If so, the engine light is on for about 15 seconds then it goes out.
Feb 17, 2006 at 1:03 AM
PEPPERMRJ
  • 1,158 POSTS
How many miles? Try some fuel injector cleaner in a couple tanks (chevron with techron) and a new fuel filter. O2 is possible but so is a lot of other things. Are there any lights/codes lit?
Feb 17, 2006 at 2:09 AM
Suggested Repair
Add Chevron with Techron fuel injector cleaner to a couple of tanks and replace the fuel filter. An oxygen sensor is possible, but other causes can produce the same symptoms; check for warning lights and trouble codes.
Conversation Summary
The owner of a 1993 Plymouth Acclaim with about 147,000 miles reports hesitation, shutting off, and power loss after a recent starter, catalytic converter, battery, and fuel-filter replacement plus a major tune-up. The check engine light comes on for about 15 seconds and then goes out. The owner asks whether an oxygen sensor could cause this and how to retrieve codes. The expert suggests injector cleaner in a couple of tanks and a new fuel filter, says an O2 sensor is possible along with many other causes, and asks whether any lights or codes are present.
