1993 Plymouth Acclaim
TIGER126
  • 1993 PLYMOUTH ACCLAIM
  • 4 CYL
  • FWD
  • 127,000 MILES
My car is smoking a grey sort of white smoke when I push on the gas pedal, and it hesitates when I take off
Saturday, April 10th, 2010 AT 9:45 PM
Inspect and test all the following listed below and get back with some results
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Sunday, April 11th, 2010 AT 6:46 AM
