HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Hyundai
Accent
Ignition
Firing Order
Firing order needed
PREV
1
2
NEXT
KEN L
MASTER CERTIFIED MECHANIC
Here are a couple of guides that will get you started on fixing the problem. This will confirm the injector problem or not.
https://www.2carpros.com/articles/how-to-test-a-fuel-injector
Cheers, Ken
Saturday, September 19th, 2020 AT 2:14 PM (Merged)
PREV
1
2
NEXT
Please
login
or
register
to post a reply.
Related Firing Order Content
2003 Hyundai Accent Replaced 0xygen Sensor 3 Times...
I Have A 2003 Hyundai Accent With A 16 Dohc 4 Cylinder Engine. My Check Engine Light Came On A Few Months Ago And I Had The Codes Read. The...
Asked by
skeis1275
1 ANSWER
2003
HYUNDAI ACCENT
2003 Hyundai Accent Overdrive Button
My Question Is, Should The Over Drive Button Be On All The Time Or Just Over 55 Mph And If It Is On All The Time Does This Hurt Anything?
Asked by
zeg minner
2003
HYUNDAI ACCENT
1997 Hyundai Accent Ignition Fuse Blows On Start-up...
In Extreme Cold, The Car Will Start But The Ignition Fuse Blows Immediately. Replacing The Fuse Doesn't Help And The Problem Only Resolves...
Asked by
lsummach
1997
HYUNDAI ACCENT
No Spark At Plugs
I Have Checked Its Getting Fuel, Replaced Coil Pack, Sparkplugs, Wires, When Key Is Turned On The Check Engine Light Does Not Come On. I...
Asked by
*rick34
1999
HYUNDAI ACCENT
Car Stopped Running, No Spark Is Getting The Spark...
Car Just Stopped Running And Will Not Start. Full Tank Of Gas, Battery In Good Condition, But It Is As If No Spark Is Getting To The...
Asked by
FrankAM
2006
HYUNDAI ACCENT
VIEW MORE
How to Repair an Engine Cylinder Misfire
Spark Plug Replacement Toyota Rav4 2006-2012
Spark Plug Replacement Ford
