No Spark at plugs
1999 HYUNDAI ACCENT
110,000 MILES • 4 CYL • FWD • MANUAL
*RICK34
I have checked its getting fuel, Replaced Coil Pack, sparkplugs, wires, When Key is turned on the Check Engine Light does not come on. I attahed a new code reader but it couldnt Link Up. There is power in the wirea in the coil pack but nothing at the plugs.
Feb 3, 2010 at 5:46 PM
No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor /distributor pick-up coil, ignition control module, ECM,Ignitor camshaft and crankshaft sensors- Note: If it doesn't apply disregard it
Feb 3, 2010 at 7:33 PM
MAX7
1999 Galloper II. The ignision fails, there is no spark to the distributor, 12 V is ok, coil is ok, the power transistor module is ok, the ignition pulse from the computer comes out. Can be pick-up coil failure?
Nov 23, 2019 at 3:38 AM (Merged)
No info on this Galloper-below is basic stuffs
No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
RICK WARNER
Ive already found no spark at the plugs. Ive replaced the coil pack, plugs, wires, still no spark. Ive attached my Code Reader, it was not able to link up. Ive turned the key to the run position and all the lights on the dash come on except the Check Engine light.
Nov 23, 2019 at 3:39 AM (Merged)
No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer.
LLUCKTHREE9
  • 15 POSTS
my car will start and run good for 20 minutes then it dies , wiat 30 minutes to hour it wll start again runs good for 20 minutes, check spark pugs when first dies no spark
BMRFIXIT
  • 19,053 POSTS
Check and replace crank sensor
LLUCKTHREE9
  • 15 POSTS
[quote:9bbc94a230="lluckthree9"]Engine Performance problem
1998 Hyundai Accent 4 cyl Two Wheel Drive Automatic 102000 miles
my car will start and run good for 20 minutes then it dies , wiat 30 minutes to hour it wll start again runs good for 20 minutes, check spark pugs when first dies no spark[/quote:9bbc94a230] thats not answer i bought the crankshaft sensor it still does smae thing anwer my vw cabroilet question i paid 5.00 for that
BMRFIXIT
  • 19,053 POSTS
was the timing belt checked ?
LLUCKTHREE9
  • 15 POSTS
[quote:036af7cef2="BMRFIXIT"]was the timing belt checked ?[/quote:036af7cef2] no but will the car run if timming belt is off, my car starts runs good for 19 minutes then it dies then wont start for another 20 minutes when it cools down then it starts again runs good for another 20 mintes no spark inbetween time when car does not run
BMRFIXIT
  • 19,053 POSTS
Yes you are correct on that with the timing belt
It sounds so much like a bad crank sensor !
scan it for codes and check pending codes too
use an ohm meter and check coil
check relays
again you have no spark after it stalls on you ?
fuel?
LLUCKTHREE9
  • 15 POSTS
[quote:83ea114c87="BMRFIXIT"]Yes you are correct on that with the timing belt
check relays
fuel?[/quote:83ea114c87] Right, but wait 30 minutes then it start up runs good
