Firing order is 1-3-4-2. Number 1 is on the passenger side, 4 is on the driver side. Here are the firing orders for both 4 and 6 cylinder engines. Check out the images (Below). Please let us know if you need anything else to get the problem fixed.
Images (Click to make bigger)
Thursday, October 30th, 2008 AT 3:56 AM
CRAIGRICE
MEMBER
1 POST
1995 TOYOTA CAMRY
2.2L
4 CYL
2WD
AUTOMATIC
Firing order - plug wire order in the distributor cap?
Thursday, September 24th, 2020 AT 11:56 AM
(Merged)
HMAC300
MECHANIC
Here is the engine ignition firing order so you can get back on the road. Firing order is 1-3-4-2 Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Image (Click to make bigger)
Thursday, September 24th, 2020 AT 11:57 AM
(Merged)
KCGJ0406
MEMBER
1 POST
1995 TOYOTA CAMRY
2.2L
4 CYL
2WD
AUTOMATIC
301,500 MILES
After researching I know that the firing order is 1342, but what do I do with that information? My wife had a friend replace the spark plugs, distributor cap, and rotor. It has been running rough ever since. Attaching a diagram.
Kavin C
(Merged)
MECHANIC
Good afternoon.
Attached is a diagram for you to view for the cap and where all the wires go.
He may have them crossed or maybe he did not gap the plugs correctly.
(Merged)
RICK FUSARO
MEMBER
1996 TOYOTA CAMRY
2.2L
4 CYL
305,290 MILES
Changed plugs wires and distributor is miss firing when you start. I think wires are in the wrong place. From standing in front of car what is firing order?
(Merged)
WRENCHTECH
MECHANIC
Check the direction of the rotation of the distributor. Bring number one up on TDC and you can look at the rotor position to determine which one is number one.
(Merged)
TOMSKI68
MEMBER
1996 TOYOTA CAMRY
1996 Toyota Camry 4 cyl
fireing order is 1 on passenger side or drivers side
(Merged)
OBXAUTOMEDIC
MECHANIC
here is the firing order.....
start from front of engine....
(Merged)
RICK FUSARO
MEMBER
New plugs wires cap n still runs rough did not replace rotor gaped plugs .44 1996 Camry le 2.2 liter engine lite on Rick
(Merged)
CACA
MEMBER
1 POST
1995 TOYOTA CAMRY
4 CYL
FWD
AUTOMATIC
100,000 MILES
Need firing order
(Merged)
MECHANIC
Hi there,
the firing order is 1.3.4.2.
Mark (MHPAUTOS)
(Merged)
SHADIZAR
MEMBER
1 POST
1991 TOYOTA CAMRY
Engine Performance problem
1991 Toyota Camry 6 cyl Front Wheel Drive Automatic
could someone please tell me the firing order for a 1991 camry v6?
(Merged)
MECHANIC
(Merged)
MYCARNEEDSHELP89
MEMBER
1 POST
1989 TOYOTA CAMRY
175,500 MILES
What is the proper timing setting for a 1989 Toyota Camry with a 3.0L V6 engine and what is the correct firing order? It is a station wagon if that makes a difference. I replaced the exhaust system from the catalytic converter to the muffler and found the timing to be ruff, I replaced the cap rotor plugs and wires with all NGK parts and it is still idling ruff.
Saturday, September 26th, 2020 AT 12:51 PM
(Merged)
MECHANIC
See below for the engine firing order the timing is - Ignition timing is 10 deg BTDC Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed. Cheers
(Merged)
MECHANIC
Before you set the timing make sure that the check wire is in, see pic below.
(Merged)
CHAPMAN06
MEMBER
1 POST
Hi. I have a 1996 2.2L 4 cylinder. I took out the spark plug wires and forgot the replacement order.
Saturday, November 28th, 2020 AT 12:11 PM
MECHANIC
Attached is the firing order for the 2.2L. Let us know if you need more info. Thanks
