1993 Toyota Camry spark plug wires broke off in spark plug
DJEBAY1986
  • 1993 TOYOTA CAMRY
  • 4 CYL
  • 23,000 MILES
I am trying to chang plugs and wires on a 93 toyota camry, 2 of the 4 plug cylinders have ends of the spark plugs wires, broke/melted off trapping the plugs beneath the rubber not allowing a plug socket to fit over the spark plug. Needle nose pliars are to big to get in there and open far enough to grab the rubber. Is ther a tool or solevent to get the rubber out so I can then take the plugs out? Please help
Tuesday, August 25th, 2009 AT 10:25 PM
  • 31,937 POSTS
Hi there,
You can get extra long nose point pliers, I have several with different angle heads the straight one I often use to do just as you need, ask your tool shop about the long series pliers.
Mark (mhpautos)
Wednesday, August 26th, 2009 AT 12:59 AM
