overheating and not starting?
140,000 MILES • 1.6L • 4 CYL • 2WD • AUTOMATIC
ZIPCLOWN
would overheat, the fan was not coming on, checked the fan and it was in fact bad, replaced it and still will not come on. still overheats. Also, the battery is fully charged and does not want to start. What would be my next move?
Aug 26, 2023 at 1:50 AM
  • 110,248 POSTS
Is the starter engaging and turning the engine? If it is, it could be a few things.
Since it was overheating, we may have a head gasket issue. When cranking the engine, does it sound normal or does it seem to turn faster than normal?
Also, if possible, record it cranking and upload it for me to hear. If it is a compression issue resulting from a failed head gasket, I should be able to tell.
I'm questioning the gasket because of the overheating issue. Take a look through this link and let me know if anything mirrors what you are experiencing or seeing"
https://www.2carpros.com/articles/recognizing-the-symptoms-understanding-a-blown-head-gasket-in-your-vehicle
Aug 26, 2023 at 3:10 PM
