1995 Oldsmobile Delta 88 Engine Revs
OPEL
PJP
1995 Olds Delta 88,6cy, 300. milage 80,000
Had been using cruise contro.
Start car, start driving, engine begins to gain speed. If you pull over and turn off ignition and turn on again car will indle normal. The minute you do any exceleration engine increases. Help
Aug 12, 2007 at 1:07 AM
  • 75,988 POSTS
[quote:61098e93a0="pjp"]1995 Olds Delta 88,6cy, 300. milage 80,000
Start car, start driving, engine begins to gain speed. If you pull over and turn off ignition and turn on again car will indle normal. The minute you do any exceleration engine increases. Help[/quote:61098e93a0]
Try this clean out the throttle body/plate and check the accelerator cable and adjustment. and may be the IACV or ISC
Aug 12, 2007 at 2:03 AM
Suggested Repair
Clean the throttle body and throttle plate, check the accelerator cable and its adjustment, and inspect the IACV or ISC.
Conversation Summary
A 1995 Oldsmobile Delta 88 with about 80,000 miles began gaining speed while driving after cruise control use. Restarting restored a normal idle, but any acceleration made the engine speed increase again. The expert suggested cleaning the throttle body and plate, checking the accelerator cable and adjustment, and considering the IACV or ISC.
