1990 Oldsmobile Delta 88 Idle Stall
OLDSMOBILE
STUNNINS2
Hi, I have a 1990 Oldsmobile Delta 88 Royale.
It's got 174,000 miles and It will stall if I don't keep my foot on the gas at all times. As soon as I let go of the gas it stalls out. For the past month the car was acting funny, it would idle very rough in drive or reverse, and not as bad in neutral or park. Sometimes it would die if I put it in gear. The only maintenance this car ever got was a new alternator, water pump, a fuel filter a few miles ago and of course tuneups. Could it be the fuel pump? I figured a plugged filter its whole life could of stressed out the fuel pump.
Thanks and please respond! I need this car up and running for college or I will have to drop out.
Jan 27, 2007 at 3:47 AM
  • 75,988 POSTS
[quote:b601d74465="StunninS2"]Hi, I have a 1990 Oldsmobile Delta 88 Royale.
Thanks and please respond! I need this car up and running for college or I will have to drop out.[/quote:b601d74465]
Before you start up-try tapping around the EGR check for improvement-if so get in there and clean out the carbon
Jan 29, 2007 at 8:56 PM
SERVICE WRITER
  • 9,123 POSTS
Find a way to not drop out of college your sacrificing your future needlessly. If Ras's suggestion doesn't pan out, Check the fuel pressure to verify it is in spec.
Stick with us, we can help.
Jan 29, 2007 at 10:02 PM
Suggested Repair
With the engine off, tap around the EGR valve and see if idle improves; if it does, clean carbon from the EGR. If that does not help, check fuel pressure and confirm it is within specification.
Conversation Summary
A 1990 Oldsmobile Delta 88 Royale with 174,000 miles stalls as soon as the throttle is released and idles roughly, especially in drive or reverse, sometimes dying when put in gear. Recent work included an alternator, water pump, fuel filter, and tune-ups. The owner suspected a stressed fuel pump. Experts suggested tapping the EGR and cleaning carbon if that improves idle, then checking fuel pressure if the EGR check does not solve it.
