1985 Olds Cutlass Sierra -- stalls when engine cold
1985 OLDSMOBILE
JOHN FISHBURN
I have a 1985 Olds Cutlass Sierra with only 36,000 miles. It is a 4 cyl. The problem is that the engine keeps dying for the first few minutes after start-up unless I keep my foot on the accelerator and also dies when it is put in gear right away. After engine warms up it idles fine. I don't know if this is related to another problem -- the check engine light does not work at all. Please let me know if you have any ideas ! Thanks !
Nov 20, 2007 at 1:02 PM
BLACKOP555
  • 10,386 POSTS
check the coolant temp sensor and sending unit, they help mix the fuel to air ratio a little more when cold to assist in cold start up. check out the IAT after the first thing suggested.
Nov 20, 2007 at 1:35 PM
And also the TPS ( throttle postion sensor ) Might also want to check out the idle air control valve and clean it.
IAT is the Intake Air Temperature sensor.
Report all your findings to Mr. B5
Nov 20, 2007 at 2:40 PM
