1985 Other Oldsmobile Models ping
1985 OLDSMOBILE
57,000 MILES • V8 • 2WD • AUTOMATIC
MIKEED
car makes a ping sound would preium gas fix the problem?
Sep 24, 2008 at 12:57 PM
BLACKOP555
  • 10,386 POSTS
could be fixed wiht premium, but if it just started pinging out of the blue there must be somethign wrong with the vehicle that should be fixed instead of coating over with premium.
i woudl start by checking plugs and wires, and the ignition timing. does it do it under heavy acceleration, slow, uphill driving? cruising?
Sep 24, 2008 at 2:36 PM
  • 75,988 POSTS
Check if you're overheating and also open up the EGR valve clean it, also investigate the knock sensor might not be retarding the ignition timing when needed.
Sep 24, 2008 at 2:37 PM
