1991 Oldsmobile Cutlass Supreme Stalls
OLDSMOBILE
SHAKEYCHEVY
91 cutlass supreme 3.1 v6...problem...car starts and runs good for a short period ... acting like its out of gas..3/4 tank at this time..i hear the fuel pump buzz when i 1st tun the key on.. i have cleaned the mass air sensor and did basic checks... when i spray a little start fluid in the air box it fires for a second...i dont have a fuel pressure gauge but i have opened the fuel schrader on top of engine.. i only get a little spurt of gas even with the key on..what do you think???t ...regulator ,filter or pump how do i test regulator??? if the pump is bad is there a access under the rear seat bottom???? i have made a small donation..thanks
Mar 6, 2007 at 1:03 PM
2CARPRO JACK
  • 11,533 POSTS
Sounds like the fuel pump. Might be drawing too much amperage and causing the relay to fail, starts but wont stay running. Gotta drop the fuel tank out of the car...... dont forget to replace the relay at the same time
Mar 6, 2007 at 11:58 PM
SHAKEYCHEVY
does this car have a low oil saftey sw that kills the fuel pump power when the oil is low????
Mar 7, 2007 at 8:48 AM
Suggested Repair
Replace the fuel pump and the fuel pump relay together. Access requires dropping the fuel tank.
Conversation Summary
A 1991 Oldsmobile Cutlass Supreme 3.1 starts and runs briefly, then acts as if it is out of fuel despite a mostly full tank. The pump buzzes at key-on, starting fluid fires it briefly, and only a small fuel spurt comes from the Schrader valve. The expert attributes this to a failing fuel pump that may overload and trip the relay, and recommends dropping the tank and replacing the pump and relay together. The owner's follow-up about a low-oil fuel-pump cutoff was not answered.
