1995 Oldsmobile Cutlass Supreme Stalls
1995 OLDSMOBILE
JAIME
today i got in my car i begin to drive i noticed it didnt feel as if it at
the boost as it normally does i didnt shut it off for atleast 30 miles i
noticed the battery light on and i noticed that it only came on when i
left off the gas and went off within 3 secd of pushing on the gas i also
noticed that when i came to complete stops it was all it had left to turn
i finally shut it off at my job and it would not crank this was 7 am at
10
sam i went out and it crunk up just great then at 12 i crunk it up drove
it
a couple of miles and it shut off again and i had to get it jumped off i
did not make it 4 miles up the road before it shut off causing the rpm to
jump back and forth asnd the sterring will to seem to be getting locked
and once again i had it jumped off only to make it about 2 miles and the
jump off and all the other repeats was completed and i was finally home
now my car is parked[/b]
Mar 17, 2006 at 11:42 AM
PEPPERMRJ
  • 1,158 POSTS
Did you check the serpentine belt and its tensioner?
Sounds like it is loose.
Good luck and let us know. :)
Try reposting in the GM section of the forum for more results.
Mar 17, 2006 at 12:06 PM
JPAM
  • 307 POSTS
bump** moved to GM forum
Mar 17, 2006 at 5:39 PM
Suggested Repair
Inspect the serpentine belt and its tensioner. A loose or slipping belt can cause the battery light, poor charging, stalling, fluctuating RPM, and heavy or locking steering.
Conversation Summary
The owner of a 1995 Oldsmobile Cutlass Supreme LS reported weak performance, a battery light when easing off the throttle, difficulty turning at stops, repeated stalling, and the need for jump starts. The RPM fluctuated and the steering felt like it was locking before the engine died. An expert suggested checking the serpentine belt and tensioner for looseness, and the post was moved to the GM forum.
