1991 Oldsmobile Cutlass Supreme CKP Sensor Fix
GMC
CRAZYMECHANIC
I have a 1991 Olds Cutless Supreme Int, with a 3.1 engine and quto trans. I am trying to locate the Crankshaft Position Sensor, and save myself $900.00.
Apr 13, 2006 at 11:09 AM
LOSONE
  • 1,616 POSTS
It is under the harmonic balancer. The balancer has to be removed to replace the unit. Good luck
Apr 13, 2006 at 11:11 AM
Suggested Repair
The crankshaft position sensor is under the harmonic balancer. Remove the balancer to access and replace the sensor.
Conversation Summary
The owner of a 1991 Oldsmobile Cutlass Supreme with a 3.1 engine asked where the crankshaft position sensor is located. The expert said it is under the harmonic balancer and that the balancer must be removed to replace the sensor.
