2000 Oldsmobile Bravada No Reverse
OLDSMOBILE
RELTNEE
I have a 2000 olds bravada,4.3engine and a 4l60e transmission, 125000 miles onthe car. I have no reverse when i put it into reverse its like it is in netural. The car shifts hard from 1 to second usually will shift from first to second if i let up on the gas
Sep 22, 2007 at 2:27 AM
JMCBRIDE1979
hard shift from 1st to 2nd is your valve body.is your service engine soon light on if so have the codes checked.
Dec 31, 2008 at 9:46 AM
BRIAN 1
  • 1,030 POSTS
the reverse reation sun shell is stripped,very common problem.there is an updated sun shell for this vehicle.trans has to torn down to fix.
Dec 31, 2008 at 10:49 AM
Suggested Repair
The reverse reaction sun shell is likely stripped, a common 4L60E issue. Replace it with the updated sun shell, which requires tearing down the transmission.
Conversation Summary
The owner of a 2000 Oldsmobile Bravada with a 4.3 engine and 4L60E transmission reports no reverse and a hard 1-2 shift that often occurs when easing off the throttle. A reply suggested the hard shift may involve the valve body and recommended checking codes if the service engine soon light is on. The expert said the reverse reaction sun shell is stripped, an updated shell is available, and the transmission must be torn down to repair it.
