1998 Oldsmobile Cutlass Power Steering Leak
OLDSMOBILE
LJBRINKMAN
I have a 1998 Olds Cutlass, 110,000 miles. All of a sudden on morning the power steering went out. We went to the parts store and bought some and filled it back up. I ran fine all day. THe next morning, same thing. No power steering, we noticed a leak....this fluid was to fix them too. What do you think could be causing this? Is it dangerous to drive it with out power steering?
Feb 10, 2007 at 2:49 AM
CHEVY22
  • 1,375 POSTS
you really need to check further to find out where the leak is from , here are the possibilities ,the pump itself or reservoir , the steering rack , check the boots to see if they are leaking fluid ,you will need to get under the car for this , or the power steering lines
jim
Feb 17, 2007 at 9:51 AM
Suggested Repair
Inspect the power steering pump and reservoir, steering rack boots, and power steering lines to locate the leak, then repair the leaking component and refill the system.
Conversation Summary
The owner of a 1998 Oldsmobile Cutlass with 110,000 miles reported a sudden loss of power steering. Adding fluid restored it for one day, but it failed again the next morning and a leak was found. The owner asked about the cause and whether driving without power steering is dangerous. The expert advised locating the leak at the pump or reservoir, steering rack boots, or power steering lines, which requires getting under the car.
