1996 Cutlass Supreme Power Steering Hose Fix
OLDSMOBILE
RCCOOK555
How difficult is it to put the long power steering hose on my 96 cutlass supreme? I can see where the hose is busted but it goes way up under the car and is very compact there. Would i be able to fix this or am i going to have to take it in to a shop? Thanks!
If i do have to take it in to be fix can someone give me a ballpark price of how much it is going to cost?
Aug 23, 2006 at 12:39 AM
MIKEYBDMAN
  • 623 POSTS
[quote:0f4a58cf7f="rccook555"]How difficult is it to put the long power steering hose on my 96 cutlass supreme? I can see where the hose is busted but it goes way up under the car and is very compact there. Would i be able to fix this or am i going to have to take it in to a shop? Thanks!
If i do have to take it in to be fix can someone give me a ballpark price of how much it is going to cost?[/quote:0f4a58cf7f]
Probably looking at $250 for labor to replace the pressure gose. That hose can be as much as $150 for the part. Either way it doesnt look like an easy or cheap job.
Aug 23, 2006 at 11:13 AM
RCCOOK555
Ok thanks for the reply!
Aug 24, 2006 at 12:20 AM
Suggested Repair
Have a shop replace the power steering pressure hose. Expect roughly $150 for the hose and about $250 in labor; the routing is tight and the job is not easy or inexpensive.
Conversation Summary
The owner of a 1996 Oldsmobile Cutlass Supreme asked whether a long, leaking power steering hose running into a tight area under the car could be replaced at home and what a shop might charge. The expert said replacing the pressure hose does not look easy or cheap, estimating about $250 for labor and as much as $150 for the part. The owner thanked the expert.
