po442 code
1944 OLDSMOBILE
SEANNIKE
I have 1999 cutlass oldsmobile a 3.1 engine, My question my check engine light is on and is showing a code of p0442 how do you find and fix the problem???
Jun 13, 2007 at 6:21 AM
SERVICE WRITER
  • 9,123 POSTS
That is a small leak in the evaporative system that controls the fuel vapors. I would start by "smoking" the system. Since this is not a machine a d-i-yer would have, look at the fuel cap and the sealing surface of the cap. If there is a question of a poor seal, replace the cap, clean the neck surface the cap seals to and lightly coat it with vaseline. IF that doesn't resolve it, your best to take it into a shop that is capable of troubleshooting this. If you do, make sure the tank is between 1/4 to 3/4 full or the test for the evap will not run.
Jun 13, 2007 at 7:23 AM
