power steering
OLDSMOBILE
LJBRINKMAN
I have a 1998 Olds Cutlass, 110,000 miles. All of a sudden on morning the power steering went out. We went to the parts store and bought some and filled it back up. I ran fine all day. THe next morning, same thing. No power steering, we noticed a leak....this fluid was to fix them too. What do you think could be causing this? Is it dangerous to drive it with out power steering?
Feb 10, 2007 at 2:49 AM
CHEVY22
  • 1,375 POSTS
you really need to check further to find out where the leak is from , here are the possibilities ,the pump itself or reservoir , the steering rack , check the boots to see if they are leaking fluid ,you will need to get under the car for this , or the power steering lines
jim
Feb 17, 2007 at 9:51 AM
