1999 Oldsmobile Cutlass Overheating
1999 OLDSMOBILE
JCHAMPION3891
PLEASE HELP I CANT GET TO SCHOOL WITHOUT VEHICLE!!! It is over heating, spilling out antifreeze in overflow there is no heat comming out at all and used to get hotter when i wasn't moving, now gets hot when moving...please help, thankyou
Feb 5, 2007 at 4:07 AM
2CARPRO JACK
  • 11,533 POSTS
Sounds like the thermostat is stuck.Replace it and be sure to get all the air out of the system
Feb 5, 2007 at 4:44 AM
JCHAMPION3891
How to I know if I did something to the gasket thing?
Feb 5, 2007 at 6:52 AM
2CARPRO JACK
  • 11,533 POSTS
Which gasket thing?
Feb 5, 2007 at 7:53 AM
JCHAMPION3891
if i blew a head gasket?
Feb 5, 2007 at 11:31 PM
2CARPRO JACK
  • 11,533 POSTS
Local auto parts store should have a "chemical test kit" it reacts to exhaust in the cooling system
Feb 9, 2007 at 1:36 AM
Suggested Repair
Replace the thermostat and bleed all air from the cooling system. If a head gasket is suspected, use a chemical block test kit that detects exhaust gases in the coolant.
Conversation Summary
The owner of a 1999 Oldsmobile Cutlass with about 80,000 miles reports overheating, coolant overflowing into the reservoir, and no cabin heat. It used to overheat when stopped and now overheats while moving. The expert suggests a stuck thermostat, replacement, and bleeding air. For a possible blown head gasket, the expert recommends a chemical test kit that reacts to exhaust in the cooling system.
