does anyone know...when replacing the heater core on the 1989 cutlas cierra, does the dashboard have to be removed?
1989 Oldsmobile Cutlass Ciera Heater Core Fix
REMOVAL:
Disconnect the negative battery cable and drain the cooling system.
Disconnect the heater hoses from the heater core inlet and outlet connections in the engine compartment.
Allowing residual coolant from the heater core to drain. Cap the openings.
Working inside the vehicle, remove the lower instrument panel sound insulator.
Remove the heater floor outlet duct screws or clips and remove the duct.
Remove the heater core cover by removing the attaching screws and clips.
Remove the heater core cover.
Remove the heater core retainers and remove the heater core
INSTALLATION:
Position the heater core in the housing and install the retaining straps.
Position the heater core cover on the housing and install the attaching screws and clips.
Install the floor outlet duct and attaching screws or clips.
Install the lower instrument panel sound insulator.
Working in the engine compartment, connect the heater core inlet and outlet hoses.
Fill the cooling system.
Start the engine and check for coolant leaks. Allow the engine to warm up sufficiently to confirm the proper operation of the heater.
Recheck for leaks. Check the cooling system level.
Thanks for using 2CarPros.com!
Suggested Repair
The full dashboard does not need to be removed. Disconnect the negative battery cable, drain the cooling system, and disconnect and cap the heater hoses at the core. Inside the vehicle, remove the lower instrument panel sound insulator, heater floor outlet duct, and heater core cover, then remove the retainers and heater core. Reinstall in reverse, refill the cooling system, and check for leaks after warm-up.
Conversation Summary
The owner of a 1989 Cutlass Ciera asked whether the dashboard must be removed to replace the heater core. An expert provided removal and installation steps that access the core by removing the lower instrument panel sound insulator, floor outlet duct, and heater core cover, along with draining coolant and disconnecting the heater hoses, rather than removing the entire dashboard.
