1987 Oldsmobile Delta 88 No Start
OLDSMOBILE
MSECASHMORE
1987 Delta 88 Royale Brougham 3.8L. Broke down on interstate 2 months ago and had car repaired at shop. ECM and crank sensor were replaced. About 2 weeks ago it stopped in the driveway and wouldn't start back. Two days later it started. Today it was missing, and running eratically when it cut off again and won't start back. Before it cut off, I went to see if all of the spark plugs were getting fire to the coil pack and got shocked. Any help or suggestions would be appreciated.
Aug 20, 2007 at 3:11 PM
  • 75,988 POSTS
[quote:5f231edc51="msecashmore"]1987 Delta 88 Royale Brougham 3.8L. Broke down on interstate 2 months ago and had car repaired at shop. ECM and crank sensor were replaced. About 2 weeks ago it stopped in the driveway and wouldn't start back. Two days later it started. Today it was missing, and running eratically when it cut off again and won't start back. Before it cut off, I went to see if all of the spark plugs were getting fire to the coil pack and got shocked. Any help or suggestions would be appreciated.[/quote:5f231edc51]
So you got shocked by Ben Franklin on the secondary lesson learned-okay -Recommend you check the actual fuel pressure by using a fuel pressure gauge calibrated for yours. and report back your findings so we can continue.
Aug 20, 2007 at 3:28 PM
Suggested Repair
Check actual fuel pressure with a fuel pressure gauge calibrated for this vehicle and report the reading before further diagnosis.
Conversation Summary
A 1987 Oldsmobile Delta 88 Royale Brougham 3.8L that previously had the ECM and crank sensor replaced now stalls intermittently and will not restart. It ran erratically and misfired before dying, and the owner was shocked while checking spark at the coil pack. The expert advised measuring fuel pressure with a properly calibrated gauge and reporting the result.
