You have 2 separate problems as I see it, and still encourage fixing them tight. Sorry I didn't finish the last post as I was interupted, but didn't want to leave you hangin.
One of the recepticles are probably bad, check to see if thereis anything inside them such as a penny shorting them out. If not pull each one out and look for a burnt spot or something abnormal. A multimeter would be ideal if you have one.
On the rear defogger, there may be a short or there may be a grid problem. You need to determine if there is power going back to it.
I empathyze that you can take a short cut to solve this. If so, fire a hole thru the firewall and put your cables thru it, seal it with caulk.
Sunday, February 11th, 2007 AT 4:25 PM
