1991 Oldsmobile 98 Electrical Failure
OLDSMOBILE
IMTHADRUMMER
  • 6 POSTS
I have a 1991 Oldsmobile 98. The problem started while driving the whole car would die for a split second, then would come back on. The readout on the dash would say "Batter Reconnected". Now nothing works, it wont crank, theres no lights. When I open the door the relay for the courtesy lights clicks repeatedly. I've swapped it with one I knew worked and it does the same thing. When I put the key in the ignition with the door open the bell dings but when I turn the key over nothing happens. I assume theres a loose connection somewhere but I have no idea where to start looking. Any help would be greatly appreciated.
-Mike
Oct 10, 2007 at 10:51 AM
IMTHADRUMMER
  • 6 POSTS
Went out and put the key in, turned it over and nothing happened as usual, but i kept turning it on and off, and it cranked up. It cut off again, but cranked back up and said "Batter Reconnected" on the dashboard read out. Could it be a faulty ignition switch or something?
Oct 10, 2007 at 11:18 AM
FISHERMAN
  • 937 POSTS
Hello Mike !..
Looks like you have a bad battery connection..
Check the terminals for corrosion disconnect it and clean the posts and connectors then tight them good also check the ground cable to the frame and to the engine make sure that its making a good solid contact !..
if the problem persist check the battery for propper voltage and holding capacity..
Let Us Know and good Luck!
(BTW Thanks a lot for your Donation)
Oct 10, 2007 at 1:41 PM
IMTHADRUMMER
  • 6 POSTS
Thats what it was, the battery terminals were corroded. But because the battery doesn't have posts, I couldn't see the corrosion without taking the leads loose. Thanks for the help.
-Mike
Oct 13, 2007 at 1:30 AM
FISHERMAN
  • 937 POSTS
[quote:df028e5038="ImThaDrummer"]Thats what it was, the battery terminals were corroded. But because the battery doesn't have posts, I couldn't see the corrosion without taking the leads loose. Thanks for the help.
-Mike[/quote:df028e5038]
Got fixed ? .. great!!
Any further questions, count with us..
Good Luck!
Oct 13, 2007 at 2:19 PM
Suggested Repair
Clean the corroded battery terminals and connectors, tighten them, and verify solid ground connections at the frame and engine. If the problem continues, test the battery voltage and holding capacity.
Conversation Summary
A 1991 Oldsmobile 98 intermittently died while driving and displayed a battery-reconnected message, then lost all electrical power and would not crank. The courtesy-light relay clicked repeatedly, and the key chime worked but the starter did not. The expert advised cleaning and tightening the battery connections, checking frame and engine grounds, and testing the battery if needed. The owner confirmed that hidden corrosion on the side-terminal battery connections was the cause.
