No electrical power at AC connector
OLDSMOBILE
OKBOWLER
1991 Oldsmobile 98, 112k miles, 3.8L
There isn't any power at the connector that plugs into the A/C compressor regardless of control/temperature/defrost settings. For as much of the wiring I can see, nothing appears damaged, burnt, or severred. Heat and fan all work fine. Where do I start looking? Thanks.
Jun 29, 2007 at 3:50 PM
ROCKWOOD84
  • 103 POSTS
i would try the a/c fuse the the relay
Jul 22, 2007 at 9:21 AM
DEK
[quote:550fe1f3a8="okbowler"]1991 Oldsmobile 98, 112k miles, 3.8L
There isn't any power at the connector that plugs into the A/C compressor regardless of control/temperature/defrost settings. For as much of the wiring I can see, nothing appears damaged, burnt, or severred. Heat and fan all work fine. Where do I start looking? Thanks.[/quote:550fe1f3a8]
Pull the plug on the Pressure Cycling Switch (It'll be plugged into the side of the Accumulator..silver canister). Take a paperclip and insert the ends of it into the plug to short out the circuit. If the compressor starts, then you have a low charge...if it does not start you have another problem which could be a bad compressor clutch.
Jul 26, 2007 at 1:23 PM
