The problem is that it will not stay running by itself for about the first 5-10 minutes after startup. Also during that time if you put it in gear and try to move it dies unless you hold the accelerator. I don't know if this has anything to do with it, but the check engine light does not come on when you urn the ignition on. There are one or two other warning lights that do not come on either. Do you have any idea what the problem might be?
SPONSORED LINKS
Saturday, November 17th, 2007 AT 6:44 PM
