I have an olds achieva 1997 and my break light and abs light will not go off and i cannot take the car out of park what should I do
Mar 9, 2007 at 11:11 AM
The symptoms point to a shift interlock cable running from the shifter to the brake pedal. Use the small override slot on the shifter base with a key-type object to release the shifter temporarily so the car can be moved, then inspect and repair the interlock cable.
The owner of a 1997 Oldsmobile Achieva said the brake and ABS lights stay on and the car will not shift out of Park, although the brake lights still work. The expert identified a likely shift interlock cable problem and described the temporary override slot on the shifter base.
