Hello
I am having a problem with a 2001 Oldsmobile Aurora, 6 cylinder. We get a check engine light and when checked the code comes back to a problem in the Secondary Air Injector Sensor. The car has the symptoms of the RPM gage going crazy and holding around the 8000 RPM range when it is clear to see that the engine is not running that fast. The car will also die on an idle down and occasionally jerks as you are driving.
I have come to believe that it is an oxygen sensor and if it is, could you please tell me how to locate those?
Thanks
Kegan Inman
Thanks
Kegan Inman
Apr 1, 2007 at 3:19 PM
