Engine problem
1992 Oldsmobile V6 Front Wheel Drive Automatic 100000 miles
The car will sit and idle but when you put it in gear forward or reverse it will shut off.
Tuesday, December 4th, 2007 AT 7:24 PM
JEFF CRANFILL
MEMBER
Does the engine accelerate in park/neutral as normal? No hesitation etc? One item to check is if the Torque Convertor clutch is locked up. If so, it would be like dumping the clutch on a manual transmission car.
