1989 Other Oldsmobile Models trouble starting when cold, act
1989 OLDSMOBILE
115,000 MILES • 6 CYL • FWD • AUTOMATIC
LITTLEMAN
I have an 1989 Oldsmobile Cutlass Ciera with 115000 miles. It has a 3300 V6. My question is when I try to start it in the morning, the engine either has a rough time starting (battery is good). When I do get it started, the exhaust smells rich of fuel. Do you think the engine is not getting enough spark to fire? When the engine is warm, there is NO trouble.
Thanks..
Feb 14, 2008 at 8:58 AM
Try testing the coolant temperature sensor/idle air control valve and the throttle position sensor-
And last check the fuel pressure with a fuel pressure tester designed for your fuel system.
Feb 14, 2008 at 9:27 AM
MASTERTECHTIM
  • 4,750 POSTS
i have run into problems with the ignition coils causing this symptom. how i determine if this is the problem i take a ohm meter across the coil towers and check resistance. the coils should read relatively the same, if one is out of whack from the others then this is your problem.
Feb 14, 2008 at 9:31 AM
