When I open the door the alarm system gose off. Then the car wont start until i disconnect the positive cable from the battery. It dose this all the time. It started after my battery died and i put a new one in. I think its the interruptor swtich from the alarm stopping it from starting. How can I disengage the alarm switch and the interruptor switch. We did not get any remote with the car. Could a faulty ingtion switch cause the same problem. You can remove the key while its running.
Oct 15, 2009 at 2:42 AM
