1999 Oldsmobile Cutlass fix
ANTONIO_KIDD
1999 Oldsmobile Cutlass 160000 miles
my car wont start, i had the battire check and that was not it. the car wont turn over.
Dec 8, 2009 at 5:07 PM
  • 75,988 POSTS
Do a load test on the battery if okay double check the connections if all else is good-now start checking the starter, starter relay, park/neutral switch and ignition switch
Dec 8, 2009 at 6:50 PM
