1995 Oldsmobile Cutlass Problems with windows & doors
MRUFFGOLF
Electrical problem
1995 Oldsmobile Cutlass 6 cyl Automatic 82000 miles
My Cutlass has recently developed multiple problems with the doors and windows. For some time, the driver's side window would not go down. When a mechanic took the door panel off to inspect, the window started working again. After a day, it stopped working again. Then, the right front door would not open. Finally, after several tries, I was able to get the door open, but then the inside light would not turn off. Presumably this is some sort of electrical problem, but before I go off to the shop, I wonder if anyone has experienced the a similar problem and what the solution was. Many thanks.
Apr 27, 2008 at 3:17 PM
CRUSHKER
I have the same problem my to front doors won't open from the inside, my windows won't go down, and my brother had the same problem with his cutlass. The best thing is just to plan how to get in and out of the thing.
Apr 29, 2008 at 1:29 PM
