If you can't just pull it up by hand, remove the trim and door panel, remove the motor, you can get rebuilds for under 100.00, and either replace the motor, or pull the glass up, or check for power at the motor connector, if there is power and the motor won't work and you cant pull up the glass remove the motor and pull the glass up. Then prop it with wood, or put the old motor back in to hold it up.
SPONSORED LINKS
Thursday, January 10th, 2008 AT 1:42 PM
