1994 Oldsmobile Cutlass wont start
JP75
  • 1994 OLDSMOBILE CUTLASS
1994 Oldsmobile Cutlass 6 cyl Four Wheel Drive Automatic
wont turn over but everything else comes on
Sunday, January 31st, 2010 AT 5:17 PM
MYOUNG4
  • 6 POSTS
First is to check for blown fuse to ignition then you must check fuel pump by checking fuel pressure with gauge you can get it at any autoparts store but be carefull you must wear eye protection you should get 40psi. After that check for ignition for spark to each wire and replace wire or plugs if faulty
Sunday, March 14th, 2010 AT 11:47 AM
